Adhesives
Large area glue up
7/25/17
NationalWood Member
I'm currently building an indoor bench that is about 20' long by 2' wide and .5' thick. The core is glulam. Miter wrapped all four edges. The top is going to be a 3/16" solid wood skin.
What would be the best way to clamp the skin while maintaining even pressure throughout? Just a system of cauls and pads? Vacuum bag is too small. This will be an all hands on deck type of situation.
7/26/17       #2: Large area glue up ...
Good luck with that. Whatever you do, don't use a glue with any water whatsoever. 3/16" solid will cup with more force than a vacuum bag can hold down. Slow cure epoxy would be my choice. You can make a one use vacuum bag from heavy vapor barrier and window mastic tape.
7/26/17       #3: Large area glue up ...
I agree with Tom's remarks. I would add that the the (thinner) top surface should be balanced with a bottom surface of the same species and thickness. This will help balance the panel and keep it flat over time.
Epoxy in a slow mix, 3/4" cauls on the entire surface, 1-1/2" or thicker cauls at clamp points. Epoxy is your friend because it does nor like or need pressure like other glues. In fact, it requires little pressure to bond well. The cauls will work to keep it all flat for level sanding.
7/26/17       #4: Large area glue up ...
Jared
+1 for Tom's idea. Epoxy and a one-off bag from visquine & butyl tape is the way to go.
7/27/17       #5: Large area glue up ...
I agree with Jared about the vac bag.
When you do a test run it will be obvious if the bag will pull down the 3/16" veneer. I would be surprised if it didn't.
You would need to build a one off vac table. We use melamine for these. Use biscuits and epoxy to glue (3) 3' x 8' sheets of 3/4" melamine to build a vac table. It has to be completely air tight. That is the reason for the epoxy butt joint. If you put screw holes in the melamine they need to be covered with epoxy or bondo to be air tight.
Cut the vac bag sheeting extra wide. It gives you plenty of room to play. It doesn't matter if the bag is huge, because the vac will suck all of the air out regardless of the bag size. Use the yellow vac bag tape to sick it down to the melamine.
This is how big composite boats and parts are bagged.
Alternatively you could use fiberglass packing tape to wrap it up every foot.
You could use west system extra slow cure hardener if you want more play time, so less people have to be involved.
Very cool project.
Vac bag sheet
7/27/17       #6: Large area glue up ...
You could alternatively make a big bag with plastic and tape and skip the table. I like the table because its stable and gives a very flat surface versus just saw horses. You could easily get a sag in the middle with knowing it. Get the vac bag table flat & straight and you know the part will be flat & straight.
