Manual case clamps - what and where?
4/6/18
Oggie Member
Till now I have been building cabinets out of 3/4 plywood, but I'm considering to add melamine too.
The way I would go with melamine is dowel/glue and case clamping construction.
From what I've learned by reading about that it looks like - for the 1 man shop building one kitchen/project at a time - manual case clamp would be a good place to start.
Unfortunately, googling 'manual case clamp' doesn't return any results?!
(except for one youtube video which you can look at by the link provided below).
Does anyone know the name of any model, manufacturer or anything what would help to locate one/some of those?
https://www.youtube.com/watch?v=CTFcZlHmvKk
4/6/18       #3: Manual case clamps - what and where ...
Steve Member
For the sake of some good pics, start with Rockler WW, http://www.rockler.com/irwin-parallel-clamp-48, or Woodworkers Supply. These appoear to be what you might use as described, one man etc. Made by the known names, Bessy, Irtwin, and a few others.
4/6/18       #4: Manual case clamps - what and where ...
Oggie Member
Thank you for the reply, but those are not what I'm looking for.
The case clamps I'm talking about are big steel frames perfectly (or at least it appears so) squared, in which you put whole cabinet against one side of that frame and than press it with a flat parallel surface from the opposite side (and usually also from the top in some non-basic, better models).
The pressing force is usually supplied by electric motor, hydraulic or pneumatic pistons etc...
Some examples of those are Gannomat Concept Easy 70, UHLING HP3000 and similar...
But, all those are overkill for my current volume of work and in this phase (which is just an intention to experiment with melamine and dowel/glue construction for a while before making any big decisions or investments).
I was hoping that manual case clamps (i.e. non-automated and non-powered) should be lot less expensive than above mentioned ones.
4/6/18       #5: Manual case clamps - what and where ...
Several new listing in March.
WOODWEB Listings
4/6/18       #6: Manual case clamps - what and where ...
Alan F. Member
Search the online auctions
See link
http://machinerymax.com/Browse?FullTextQuery=case%20clamp
If you are willing to take a few months you can find a good deal on a good clamp
Industrial recovery auctions
4/6/18       #7: Manual case clamps - what and where ...
Alan F. Member
And of course here
Woodweb
4/9/18       #8: Manual case clamps - what and where ...
Bruce H
I have a Uhling case clamp. WAY nice.
Uhling Case Clamp
