biesse
4/25/16
luke Member
I have biesse cnc that gives me an error that the tool in the magazine does not match the cone test. The tool is loaded and it says its not. I ran my program and when it went to switch bits it stalled out and said the magazine was empty. I have unloaded the tool and loaded it back and I still get this error. I have shut down completely and it still doesnt work!
4/25/16       #2: biesse ...
Dex
Have you confirmed that whats in your magazine matched whats in the Biesse machine configuration? I have found that if I dont do a proper shut down with the "find kill reset " that it forgets where my tools are.
But if the tools didnt match up you should also get an error when you try to optimize in Biesse editor at the machine.
Either way, call biesse directly they have great support and phone support is free.
4/25/16       #3: biesse ...
Dylan Bayliss  Member
as above call Biesse to walk you through
704-357-3131
It could be that the tool change was interrupted and the name does not correspond to the info in the database..untool the spindle through the software and remove tool from spindle and place in the correct location on the tool changer..should fix itself once you do that
dylan
www.machineconsult.com
4/27/16       #4: biesse ...
Dex
Have you gotten a solution? I'm curious to know what it was .
4/28/16       #5: biesse ...
luke Member
I had a tech from biesse come out and the problem was that 2 of our tool forks on the magazine were cracked. Apparently there is like a .0005 mm tolerance, so with it cracked it was pushing down on it and not reading the correct height.
8/8/16       #6: biesse ...
Mike McClaran
Luke,
We have those in stock and ours don't break.
We also have many other parts for your Rover. Give us a call 909 606-0140
2/9/19       #7: biesse ...
Jared Member
I'm having a similar problem with my Rover J. When a tool holder is present in the spindle, the sensor reads as no tool holder. When the tool holder is absent in the spindle, the machine functions perfectly. Could this be a polarity problem? Or a setting on the hand held controller?
I appreciate any and all suggestions.
Thanks.
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
    • Biesse America
