3d wall panel question
8/27/16
ag Member
hi all
i am new to the cnc word and i want to make a 3d wall panel any tips on what bit to use ? and how can i get a clean design do i have to sand it
thank you in advance
8/28/16       #2: 3d wall panel question ...
james mcgrew Member
Bit choice is based on desired end look, Ball nose .25 to 2" and v bits from 90 and 60 degree .25 wider to 1.5 even 2" wide. i use Aspire software to create patterns and the files are for sale on ebay in some cases.
9/5/16       #3: 3d wall panel question ...
ag Member
thank you James mcgrew for your response i am new to the cnc world and i want to make some wall panels
where can i find some tutorial on how to make them and is it hard to make wall panels 3d designs
9/5/16       #4: 3d wall panel question ...
james mcgrew Member
All of the above are not 3d files, they were made using 2 d toolpaths in Vectrics Vcarve pro or aspire. the base program of each will do this, aspire adds 3d. the demo is full version try it.
6/24/21       #5: 3d wall panel question ...
MusBen
Hello,
I am very new to CNC world and I would like to know the material used for 3D wall.
Any resources about the subject is welcome.
Thank you.
6/24/21       #6: 3d wall panel question ...
james e mcgrew  Member
MDF, (HDF is better) HDU, and i have even done some in Cast acrylic
6/24/21       #7: 3d wall panel question ...
musben
is it okay with this kind of PVC (Forex)
https://www.display.3acomposites.com/forex.html
I will also check MDF
