spoilboard cutters
8/8/17
duster
Website: sunvalleywoodworks.com
I'm looking for advice on spoilboard cutters. My first cnc will be arriving next month, equipped with a 10 hp atc spindle.
In addition to surfacing mdf spoilboards, I'd like to also surface the live edge slabs I occasionally work with.
I've looked at offerings from Vortex and Amana in 2" - 4" diameters, and 2, 3, 4, & 5 wings. Some of the Amana's have inserts on the bottom as well as the edges, where the Vortex's are only on the edges.
I'd appreciate any feedback on what might work well for me.
8/8/17       #2: spoilboard cutters ...
B
I use a 2.5" insert fly cutter from usroutertools. Body was pricey but inserts are cheap. Works great for everything. Resurfacing or planing big tops.
8/8/17       #3: spoilboard cutters ...
B
Forgot to mention it's just a 2 wing.
8/9/17       #4: spoilboard cutters ...
2" diamond. Also use it for one piece MDF shaker doors.
8/9/17       #5: spoilboard cutters ...
Chuck Hicks Member
Thank you B, We are the company that is supplying those to US Router. We do have these from 1 7/8 Dia to 4" Dia, with some of those with 3 Wings also. We use the 4" dia x 3 wing on our CR Onsrud here at SE Tool for our machine and spoilboard and have had great success with it.
View higher quality, full size image (5312 X 2988)
8/9/17       #6: spoilboard cutters ...
Jared
I use the Vortex 4" for spoilboard flycutting and the Amana 1.5" RC-2250 with bottom cutters to flatten slabs, among other things. The Amana's inserts don't seem to last long: the bottom cutters wear out much quicker than the side ones, and they're slightly different sizes and thus not interchangeable. Baffling.
8/9/17       #7: spoilboard cutters ...
I have used both Onsrud and Vortex 4" 3 wing fly cutters over the years. Both have performed well. I think my current one(Vortex) is about 10yrs old.
8/9/17       #8: spoilboard cutters ...
duster
Chuck - I noticed some of your tools are offered with an upcut configuration for a roughly 15% upcharge. Is there an advantage to this style compared to the straight ones?
8/10/17       #9: spoilboard cutters ...
Chuck Hicks Member
Duster,
The upshear is mostly for the stringy type material like the balsa core. 80-90% of the ones used are just the straight face.
You can also use hard grades of inserts in our cutters if needed, for a high wear applications.
