Optimize parameters for mills with tips
3/13/18
Norm Grimberg  Member
Website: http://mdaltd.ca
Hello
Thank you for entering in my post How important is optimizing parameters for a mill with tips? We assume we have a 50mm cutter on the same pass (same plunging depth, same spindle speed) If we machine this pass with a feed of 800mm/revolution rather than 1600mm/rev (optimized) Can we say that we are not only taking double time to do the same job but we are also wearing the tips? I remember that the supplier of the tips normally gives you the contact time (the actual time that the tips can be used to take material off) and after that, you should change them or at least checking them to see if they can do more than that Can we say that optimizing parameters saves time and tips? Any suggestion according to his matter will be very appreciative
