Looking for a welder.
3/28/18
Norm Grimberg  Member
Website: http://mdaltd.ca
Hello everyone. I'm looking for a good 110v welder. What does everyone recommend?
4/9/18       #2: Looking for a welder. ...
Ken Member
Hobart Handler 140, Miller Millermatic 141, or a Lincoln whatever. Also consider the models that run both 120/240. You won't regret it if you in the shop and have a heavy project to work on, like a trailer.
4/13/18       #3: Looking for a welder. ...
Ray
depends on how much you want to spend do you want flux core or gas dual or single voltage. I have a miller tig machine that uses argon and several other mixed gases , I can also add a spool gun to it for wire welding. it's dual voltage. I have only welded with miller welders so I'm partial to them.
9/30/21       #5: Looking for a welder. ...
Frank McGuire Member
It depends on the price range and how do you want to use it, purposes. As said above, Hobart 140 is a decent one, also take a look at Weldpro and Forney's welders
https://weldzone.org/best-120v-welder/
    • Country Saw & Knife
    • Palmetto Cabinet Doors
