HDF verus MDF plum creek
2/7/20
Billy Lobb
We make cabinet door out of mdf what is the advantage and disadvangee of using hdf in this . I havent cut but one small piece of hdf but it seen to cut good and sand . We will making one piece srp door. Using plum creek material. Thank
2/7/20       #2: HDF verus MDF plum creek ...
Robb Parker  Member
We use Plum Creek. Have tried many others and it is the best we have found. We make about 50-150 doors per month.
2/7/20       #3: HDF verus MDF plum creek ...
Billy Lobb
I should have wrote Hdf plum creek versus Mdf Plum creek compare which one is better,
2/9/20       #4: HDF verus MDF plum creek ...
cabinetmaker
Call Plum Creek.
2/11/20       #5: HDF verus MDF plum creek ...
Pdub
We used HDF for awhile. Thought it was great. Painted much better (easier) and the edges were a lot harder.
Then we noticed that the larger HDF panels were warping and liked to stay that way. Had to replace a few doors because of it. Now we're back to high quality MDF.
6/15/20       #6: HDF verus MDF plum creek ...
Jason Scott
I have used thousands of sheets of the HDF over the years. There is a big difference between the HDF and MDF when milling doors. HDF paints better and mills and sands better too. The downside is you have to lift it.
