Need a good wood filler
4/21/15
Ted Member
I've been using Famowood water based filler for some panels I make. the panels are curved and laminated. The thing is the way they are put together there is a gap that needs to be filled before they are painted. The gap is about 1/4" at the widest point and progresses down to a hairline at the other extreme. Previously the panels were always painted a dark color so that it didn't matter if the filler shrank a little and created a hairline crack. It wasn't visible. But some I'm making now are going to be painted white so any hairline crack will stick out like a sore thumb. I haven't yet tried Famowood's oil based filler but I wonder if any of you have experience with that or another filler that will fill a wide crack, dry hard and won't shrink?
4/21/15       #2: Need a good wood filler ...
Jared
Consider an epoxy with a thickener in it, like West System with colloidal silica. Hard as a rock when dry; I can't recall ever having a filled joint crack after paint.
4/21/15       #4: Need a good wood filler ...
1/4" gap? Holy cr@#! Glue a piece of wood in it.
4/22/15       #5: Need a good wood filler ...
phil v
bondo works great on painted
4/22/15       #6: Need a good wood filler ...
Ted Member
Hey, thanks for answers one and three. I haven't seen the epoxy and while that sounds good, my next door neighbor is a body shop so I can get some Bondo from him. Think I'll try that first.
4/22/15       #7: Need a good wood filler ...
Robert Member
Whats wrong with the most obvious of answers...# 2 ? I might have used a different word than Holy cr@#! to describe the 1/4" gap but I'm quite sure it would have been modified. But come on.. 1/4" is a monstrous gigantic gap to cram Bondo into.
4/22/15       #8: Need a good wood filler ...
Thanks Robert. The deal with a 1/4" line of any filler is that wood moves from season to season, bondo and filler doesn't. First time the wood shrinks up a little, that much bondo either cracks, or telegraphs through the finish. That's just too much to fill and keep a good paint job over a length time. There has to be a better way with your processes to tighten that up! If I have a 1/4" gap, it's going in the burn barrel.
4/26/15       #9: Need a good wood filler ...
Bill Richardson  Member
Website: http://www.awwtx.com
Maybe a better explanation would help, because quite honestly a 1/4" seems pretty excessive to me as well. And expecting a rigid filler to bridge that much of a gap in a wood product is unrealistic.
