Kremlin pick up tube filter
9/9/16
Kevin
Does anyone out there know of a stainless replacement filter assembly that will work for the 10-14 pumps? I feel like I go through the plastic ones pretty quick. Often times, the plastic holders seem to wear out and will not hold on to the filters. Kremlin parts are so pricey, would like something I can clean and re use.
9/9/16       #2: Kremlin pick up tube filter ...
dar
worthy screens
9/9/16       #3: Kremlin pick up tube filter ...
Leo G
Never even used my pick up screen. It's still pristine.
9/10/16       #4: Kremlin pick up tube filter ...
Dan cook
Who sells the worthy screens. Googled it and didn't find anything.
9/10/16       #5: Kremlin pick up tube filter ...
Bruce Hand Member
Here is one of many sources
Bruce
View higher quality, full size image (534 X 480)
9/11/16       #6: Kremlin pick up tube filter ...
herb johonson
these strainers are more like a rock catcher, typically less than 40 mesh
certainly better than nothing
good luck
herb j
9/11/16       #7: Kremlin pick up tube filter ...
Bill Richardson
I bought the EOS C10-18 and it came with a stainless screen. It should fit the 10-14.
9/12/16       #8: Kremlin pick up tube filter ...
Kevin
That's interesting Bill. Is the filter housing/clamp stainless as well?
9/13/16       #9: Kremlin pick up tube filter ...
Bill Richardson  Member
Website: http://www.awwtx.com
If we're talking the same part, yes. I assume your referring to the screen at the end of the pick up tube that goes directly into the bucket of coating, which on my Kremlin is threaded on.
