Thinning Lenmar Plus, conversion varnish
11/11/17
Willem Martins  Member
Website: thelastwoodworker.com
Anyone using this product and thinning it?
Can normal lacquer thinner be used, or must it be the Lenmar Lacquer thinner they mention on their data sheet?
The latter is pretty expensive for cleanup and thinning.
Product data
11/12/17       #2: Thinning Lenmar Plus, conversion va ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
Yes, I use it and love it.
I'll never go back to lacquer after using a
conversion varnish.
I thin it 40%.
the thinner they use is lacquer, but most lacquer
thinners on the market today are reconstituted junk.
I use auto grade urethane reducer.
More expensive but works great.
11/12/17       #3: Thinning Lenmar Plus, conversion va ...
Michael Foscone  Member
As Jim stated, most lacquer thinners on the market are junk. Primarily because there is no set formula for it. So the manufacturers just add what they want.
I use Mohawk thinner and also reducers.
ML Campbell regular lacquer thinner would be fine as well.
Best always to use the lacquer mfgrs.reccomended thinner, unless you really know.
11/13/17       #4: Thinning Lenmar Plus, conversion va ...
Pete Anderson  Member
Website: petesfloors.wordpress.com
I have used isopropyl alcohol to tho conversion varnish for spraying.
11/13/17       #6: Thinning Lenmar Plus, conversion va ...
Thanks guys for the information. I can't find their thinner 1A.406 anywhere online or at a store within 50 miles. So I called them and the suggestion is to either have a retailer order it in, or experiment with a normal hardware store lacquer thinner which may not be optimum, but may be OK. I normally spray pre-cat lacquer, very forgiving, very easy, but needed the most durable available for this job. Lenmar says this process needs to be a little more precise. We will see how it goes.
11/13/17       #7: Thinning Lenmar Plus, conversion va ...
Jim Clark  Member
I was told to use auto grade urethane reducer by a paint chemist that owns a paint company. An expert in this field.
Once I tried conversion varnish I wondered why anyone would use lacquer.
11/14/17       #8: Thinning Lenmar Plus, conversion va ...
Jim
I am curious why you thin it by 40%. Assume it is a lot easier to spray and use more than two coats?
11/15/17       #9: Thinning Lenmar Plus, conversion va ...
Jim Clark  Member
I don't know why. it's just what I've always done.
What's the recommended ratio?
I usually spray 3 coats.
11/15/17       #10: Thinning Lenmar Plus, conversion va ...
Their tech sheet says thin no more than 10%, two coats, below 5 mils.
If 40% works for you, I might try the same. Spraying thin coats are a lot more forgiving.
1/11/18       #11: Thinning Lenmar Plus, conversion va ...
Sprayed the first job with this product, no thinning, straight out of the can, in 68F temps and it worked really well. No issues, sands well after 25 minutes, followed by a second coat which is more than enough. I put this over a Minwax oil based stain after consulting with Lenmar, who said it would be OK provided the stain is dried properly. The only catch is measuring the catalyst accurately, as 2,3% by volume is not easy to do. The specific gravity (density) of the catalyst is less than the finish, so I did 3% by weight.
