Moulding Sprayer
1/23/19
Dale Skipper  Member
Website: http://www.oaktrim.com
Hey Folks,
Been running a custom trim shop for 23 years now. Been considering for years to put in a moulding sprayer and offer our products 'pre-finished'. These days we are running mostly poplar which is being painted.
Thinking of installing a moulding sprayer and offering 2 coats primer and 1st coat of paint as a value add. Looking for advice - has anyone here in this forum ever done the same? Is it worthwhile?
Thanks in advance,
Dale
1/24/19       #2: Moulding Sprayer ...
Shane
I work for a large commercial shop that runs 10's of thousands of feet of different profiles on large commercial projects. We have two lines for linear spraying. We have older (2006'ish) Makor Iride machines with the profile sanding section (Flexible/positionable heads) and at the end we have the automatic rack stacking machine.... We keep the sanding unit and stacking machine on rails in the floor to roll between the two irides depending on what machine is running production.... One iride for stain/clear finishes and the other for priming and opaque topcoats. The machine can sand,spray & stack material up to 10" wide... it can do wider but you run into coverage issues as well as stacking issues. We normally spray primed trim at 100-120 ft a minute with two circuits blowing six Kremlin AAA guns on difficult profiles.that's pretty stinking fast.... For prime I use kem aqua water borne primers... by the time you run 12 racks of material you can pull the first rack back and begin flipping and running your next coats....Well worth the money.. it's a one man operation... two is helpful
1/24/19       #3: Moulding Sprayer ...
Dale Skipper  Member
Thank you Shane - I appreciate your response. Sounds like an excellent operation!
