Professional edge on laminate without filing
3/17
Hello Fellow Woodworkers,
Does anyone know of a method or a special tool that avoids one having to file laminate while having a professional edge?
3/17 #2: Professional edge on laminate witho ...
I've tried a couple of other ways, one is a special bit called a no file bit. You have to be careful when adjusting because the straight part of the bit can cause the infamous white to show. I still had to file after using this bit. Theres no better way that i've seen to get a professional looking edge than good old hand filing.
3/18 #5: Professional edge on laminate witho ...
Deran Amana tool makes a great no-file bit in two different sizes 1.5mm rad. and 0.4 mm rad. They work well.
3/19 #6: Professional edge on laminate witho ...
Website: http://Mr-cabinet.com
Has anybody tried scarfing the edge with
a steel wood scraper? I am now an "old timer" and when an "old timer" showed me the technique, a file seems primitive.
A file works better for the corner edge of a drawer front, no doubt, but on the majority of the laminate self edge finishing, the scraper will polish, and finish the edge absolutely
beautifully, in a rapid and controlled manner. I would encourage any of you to try this on a self edge joint that has been bevel trimmed with a small amount of overhang remaining.
Play with it, you won't be sorry.
I have done miles of the finest self edge using this technique.
Best Regards, Chip
3/20 #7: Professional edge on laminate witho ...
Chip,
That sounds interesting. Could you elaborate on that process of using a scraper? Maybe post a picture of the scraper you use.
Thanks, Mac
3/20 #8: Professional edge on laminate witho ...
Thanks for the tip Chip, although I find it ironic that with your name you are telling us how to work laminate.
Something that is obvious but in case it is not: dialing in the bevel trim on the router greatly reduces the amount of filing you have to do.
Pat
3/21 #9: Professional edge on laminate witho ...
Chip----I've done it your way for years, using a block plane blade works too.
3/22 #10: Professional edge on laminate witho ...
Pat has it right on- dial in that bevel router
leaving just a smidge of overhang.
The scraper used is a common wood scraper. Ours is 2-1/4" x 6". Burnish the scraper edge just like you were going to scrape wood. Drag it along the protruding laminate edge overhang lightly and you will see it cleanly scarfs the edge. Usually I will use
3 or 4 passes lightly in 1-2 ' increments
rounding and polishing the edge, while working my way down the length of the top.
We also put a piece of tape on one corner of the scraper which can rest on the front edge of the laminate without scratching it, while scraping the miniscule laminate overhang.
Another nifty tip is: we spray our contact cement, when we mask the front edge for overspray protection, we hold the tape back 1/8" from the top and let a little "telltale" dried overspray be the indicator when the scraping/filing is done.
I hope this gives you a little more to work with.
Best Regards, Chip
3/23 #11: Professional edge on laminate witho ...
Dean, we currently have our version called a easy edge bit. Mac is correct, the position of the bit is critical. What you need to keep in mind is the thickness of the laminate. This plays a part in which bit you need.
Buy & Sell Exchanges | Forums | Other Resources | Site Map
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Project Gallery
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
