Maple veneer cross grain seam--best way to hide it?
4/1/15
Mel
I have a close to 9 foot long mantle that will require a veneer layer on the face.
I will have to use a seam (cross grain)-- as none of my veneer sheets are that long.
Anyone got a handy-dandy slick trick to have the seam be the least visible possible?
4/2/15       #2: Maple veneer cross grain seam--best ...
Use longer veneer. I've seen them trees - they are taller than 8' for sure.
Seriously, get some raw veneer and use it full length. Or consider shop made veneer, sawn and sanded to 1/8" or so. Or change the design to allow a mock frame and panel so that there is no need for a butt joint. 3 solutions....
To answer your question, a butt grain match is the best way, and even then it is obvious, just not quite as obnoxious.
4/2/15       #3: Maple veneer cross grain seam--best ...
Mel
I also think making the veneer is the best way. They are convinced it's too time consuming? Maybe I should see if I can push this one a little.
But yeah, butt joints really aren't great.
4/3/15       #4: Maple veneer cross grain seam--best ...
I can tell you that I love to see butt joints in veneer. In my competitor's work.
It shows that the maker does not care to go beyond the quickest, cheapest, most convenient solution, and the quality or integrity of the work be damned. It also does nothing to set the shop apart, but helps keep it slogging away in the trenches with the mud, the blood and the beer.
When I worked for others, my question would be "What did you sell them? What was specified?" and of course, no one ever thought of it until it had to be done.
Post the specifics here - species and dimensions, and I an tell you how long it will take to do. Certainly more than a piece of paper-backed and contact, but it wil also be something your people can point to and say they did not take the path of least resistance.
4/4/15       #5: Maple veneer cross grain seam--best ...
Mel
6 1/2" x 100" strip of maple veneer needed. (dimensions account for the extra needed for application ease.
They take the path of least resistance till I pester the heck out of them with hard facts (that I get here).
David, you rock :)
4/4/15       #6: Maple veneer cross grain seam--best ...
Gary B.
Mel,
I wouldn't even consider a butt joint for that length; seriously...maybe 15' or so; then a matched butt joint from the same flitch of veneer. No need for shop made veneer here. Call any of the great veneer houses we have here in the states. I like certainly wood.
4/4/15       #7: Maple veneer cross grain seam--best ...
Mel
Gary--100% agreed. It's not the right way, for sure.
We are in the country up north with all the igloos--we do have extra long veneer, but "OMG!! We have to custom order it! Mind blown!"
Baby steps. That's okay, we'll get there for sure, in time. Everyone is workable.
But it's good to know I'm not crazy on this one--that thing is not going out with a seam. It's just the right thing to do--it's going to live in a person's house. It should be really nice.
4/6/15       #8: Maple veneer cross grain seam--best ...
Contact A&M in Ontario to avoid customs. They are definitely in the 'boutique' class of vendor, but good materials and service.
But before you have that URL up in your browser, I would have 2 pieces of 4/4 x 110" Maple ripped to 3" wide, S2S'd and then in the bandsaw (or tablesaw) to resaw into 3 x 2 pcs at <1/4". Then to the planer or sander to take it down to 1/8". Pick your preferred show parts, and edge joint with glue to make two faces (balanced panel), and add the edge band (from when you ripped the 3" pieces) to your corestock before laminating the faces on. Use Gorilla glue/similar for the lamination, as you do not want to add water to the 'veneer'.
Bob's your uncle, you'll be waiting on the glue to set long before you see any UPS truck bringing veneer.
A&M Wood Specialty
4/7/15       #9: Maple veneer cross grain seam--best ...
Mel
"I would have 2 pieces of 4/4 x 110" Maple ripped to 3" wide, S2S'd and then in the bandsaw (or tablesaw) to resaw into 3 x 2 pcs at <1/4". Then to the planer or sander to take it down to 1/8". Pick your preferred show parts, and edge joint with glue to make two faces (balanced panel), and add the edge band (from when you ripped the 3" pieces) to your corestock before laminating the faces on."
Boom--there it is. I can for sure sell that option, and do it.
Not sure if this is crazy, but just wondering... If I wanted to get thinner veneer--could I make em extra long, spot glue ends to a thicker peice, then thickness-sand it thinner?
4/7/15       #10: Maple veneer cross grain seam--best ...
A piece of MDF and some 3M contact spray adhesive (black can) is kept by the wide belt to lightly adhere thin stock to the 1/2" for sanding.
Every now and then a piece would come loose and self destruct. You want a tackiness like a strong Post-it, and the full length.
4/9/15       #11: Maple veneer cross grain seam--best ...
Mel
Hah!--total belly flop. Thing will go out with ugly a$$ seam. Sad Melly. Good sales pitch, bad timing. Bah :(
5/29/15       #12: Maple veneer cross grain seam--best ...
hardwoodfloor  Member
Website: http://hardwoodfloorsrefinished.com/
Change the design to allow a mock frame and panel so that there is no need for a butt joint.It shows that the maker does not care to go beyond the quickest, cheapest, most convenient solution.
5/29/15       #13: Maple veneer cross grain seam--best ...
Mel
I had almost forgotten about that thing... Shameful atrocity. I fought tooth and nail to do it another way... But at the end of the day, the boss is the boss.
