Solid Wood Machining
Smaller (20") planers with segmented rollers?
10/3/17
Matt
We're considering upgrading our planer to something with segmented infeed rollers to assist in being able to plane multiple pieces (2-4 pcs 2" wide) at a time.
Our current machine is a 12 year old Grizzly, 15", which has actually been a good little worker for us, and still functions as intended. It has the solid roller, so any time you run more than one piece, you may get a stop/go effect, you may not.
I've had a hard time finding anything but a Grizzly model that's 20" with segmented rollers, and that model has no reviews whatsoever.
10/3/17       #2: Smaller (20") planers with seg ...
Why 20" not 24" ? Do you have 3 phase?
There are lots of good used machines on the market.
Here is one coming up at auction.
http://www.irsauctions.com/popups/hireslot_pict.asp?pict=370256j.jpg&lot=37025
6&letter=j&auc=AJBOC5GRQ7T68OSKHY0TBTFUM1OL4O&src=
You may never need to plane that wide but if you use the whole bed (which you should) the knives stay sharp longer.
Good luck!
10/3/17       #3: Smaller (20") planers with seg ...
SCM makes one.
SCM Planer
10/3/17       #4: Smaller (20") planers with seg ...
You can do very well with an older Powermatic that comes in widths up to 24". P-matic stopped making these about 18 years ago, but there are hundreds of them around. Many school shops had these as standard equipment.
These are heavy duty workhorses that can also do fine finish work. Get one with a grinder, and you never have to send out knives.
Most have segmented indeed rollers, but not all did so check on that. Basic parts are available. We changed bearings and belts and indeed roller internal springs on ours and it is like new.
I believe that segmented rollers are for feeding different thicknesses thru the machine. Once the parts are the same thickness, a solid indeed should feed them unless something is out.
10/5/17       #5: Smaller (20") planers with seg ...
Andrew J. Coholic  Member
Website: http://www.joecoholiccustomfurniture.com
Cantek, I have a 20” HD model with digital setting, segmented feed roller and all around an excellent machine. Been using it daily since early 2011 in our 3 man shop. 7.5 hp.
