Solid Wood Machining
72'' or longer straight metal bar
2/7/18
Stefano
I'm looking for a precise 72'' or longer bar to check that the wood is straight after dress. Anyone has any suggestion?
Thank you
Stefano
2/7/18       #2: 72'' or longer straight metal bar ...
Ken Member
Straight is relative, I have a nice high end 72" Empire level with a machined edge that's marked .0005 per inch (.006 per foot). But as far as I can tell it's dead straight across a jointer or TS table. Starrett has 72" straight edge (380-72) spec. .0002 per foot. Also the cement industry has some nice aluminum straight edges, might be a option to get a longer one and have the edge machined.
https://www.homedepot.com/p/Empire-72-in-Aluminum-Box-Level-650-72/303215470
2/8/18       #3: 72'' or longer straight metal bar ...
Starrett makes them up to 72" and has three choices on their website.
We have a few wooden woods that we true be placing them against each other, and the try on the joiner if needed.
We depend upon the eye also for straight. Surprisingly accurate once you work at it a bit.
I have only seen long straight edges used for setting up large joiners.
2/8/18       #4: 72'' or longer straight metal bar ...
stefano
Thank you for the suggestion!
Stefano
2/9/18       #5: 72'' or longer straight metal bar ...
brad
McMaster Carr has a good selection.
I needed a long straight edge not long ago, and talked to my local machinist. They got me a piece of 1/2"x2"x9'-0" key stock to try. I use that and machinist 1,2,3 gage blocks to check long rails on a piece of equipment. I ran my 36" long certified straight edge along the edges and could not fit any of my feeler gages between the two along the length of the bar.
2/10/18       #6: 72'' or longer straight metal bar ...
Pete Anderson  Member
Website: petesfloors.wordpress.com
A hollow magnesium straight-edge works for me.
Magnesium Straight Edge
2/12/18       #7: 72'' or longer straight metal bar ...
Adam West  Member
An aluminum extrusion would be your best bet.
2/13/18       #8: 72'' or longer straight metal bar ...
Bruce H
Crain make one for carpet.
Crain Straight Edge
4/8/18       #9: 72'' or longer straight metal bar ...
David Waldmann
I've yet to find a situation where two of the pieces we've just straightened/flattened placed back to back is not sufficient to check straightness.
Then again, the only reasons we have for checking straightness where the eyeball isn't enough is aligning our gang rip or truing the jointer if it gets out of whack.
And the only reasons those matter is to make moulding as straight as possible, or creating a glue joint that can be clamped tight.
