Solid Wood Machining
Grizzly 18-36 Drum SDander
5/11/19
roger78 Member
I have a 18x36 Grizzly drum sander and it is leaving peaks and valleys in the wood. I am using 100 grit paper and have adjusted speed rate from low to high and. I adjusted the amount of sanding to almost nothing and up to 1/32 and still leaves peaks and valley's across the width of the work piece. The machine is just 2 months old.any advise will be appreciated. Thanks
5/16/19       #2: Grizzly 18-36 Drum SDander ...
18/36 tells me it is an 18" drum with one end open for wider work. These are lightweight machines. Just because you set a thickness does not mean iiiill be that thickness.
I think you will only be able to remove a few thousandths per pass. The 'hills and valleys' are created by the open end and a belt that is less than capable. Most sanders require better belts. The low cost sanders especially will require the best belts one can find.
5/17/19       #3: Grizzly 18-36 Drum SDander ...
roger78 Member
Thanks for your response. Do you have a preference on the belt manufacture?. Yes I have an open end. I changed paper from 120 to 100 and seem to do better. But I noticed if I rotate the board 90 degrees I get the valleys. I have the sander head as close to parallel as can be. So as long I do not do wider than 18 inch it seems to be good.
5/17/19       #4: Grizzly 18-36 Drum SDander ...
So do you really have a drum sander, or do you have a belt sander? Why would you need belts for a drum sander? I think your expectations are too high for using an $800 machine to surface 36" wide panels in a commercial situation. You're getting exactly what you paid for.
5/18/19       #5: Grizzly 18-36 Drum SDander ...
roger78 Member
yes it is a drum sander I have 4 belt sanders so I know what they are. David suggested a new belt that pulls the wood through the drum head.
5/23/19       #6: Grizzly 18-36 Drum SDander ...
I agree with rich that you should not expect to get perfect - even good - results with the equipment you have. Getting the center to level and keep off the other defects will be near impossible. Drum sanders are a relic of a time before wide belt sanders were developed. They clog with glue and overheat. Wide belt sanders benefit from a wide surface that will be sanded in one pass, and a longer belt is better, for heat dissipation.
