Veneer
Veneering a mdf raised panel
6/26/14
Kenny Member
Website: http://Cabinetrybykmc.com
I have extra lg. panels to create and would like to use the method of a mdf substrate w/ a cove raise on 4 edges. Glue a veneer on back using a vacuum press. What type of veneer would I use for the face to be able to roll down on the cove raise? I would break all corners. Wood on wood ? 20 mil? 10 mil? Arkansas Wood Doors does this but paying shipping for 4'x7' panels would not benefit me.
6/26/14       #2: Veneering a mdf raised panel ...
Max Neu
You could make the Cove a separate piece, hold it down about 1/16", to create a step in the profile.
6/26/14       #3: Veneering a mdf raised panel ...
Kenny Member
Rather not. A whole face veneer will finish much better and uniformly. Thanks for the suggestion.
6/26/14       #4: Veneering a mdf raised panel ...
Those type of panels are made with a membrane press to force the veneer down into the coves. I t has been 20 years ago, but I watched a company try to perfect the process to get away from their 25% failure rate. The coves have to be very shallow, or the veneer will wrinkle. The proper thickness, MC, glue and everything else had to be just so, and then they still had the failures. They were pressing onto particle board, and heat was also part of the process. I remember seeing skidloads of failures being wholesaled off for 25.00 per skid.
There are better ways to do this - one way is to miter MDF with solids, veneer, then raise the panels. That has worked for several centuries, although cross banded lumber core was used before man made corestock.
6/26/14       #5: Veneering a mdf raised panel ...
Kenny Member
Well that's not good news. Thanks for the feedback. You rang a bell. I do remember seeing a shop do what you mentioned but did not even miter the solid stock. I saw portions of the end grain on the cove. This is not a commercial job so maybe miters will be the key.
6/29/14       #6: Veneering a mdf raised panel ...
Geoff
I make panels this way sometimes and most people don't notice. I have thought about using end grain on the top and bottom of the panel but never have. It works great for over sized panels.
6/29/14       #7: Veneering a mdf raised panel ...
A mitered perimeter and veneered stable core is AWI Premium Grade construction. It is always thought to be superior to solid raised panels in many shops.
7/7/14       #8: Veneering a mdf raised panel ...
Ed
Website: http://www.qualityvak.com
Go to http://www.qualityvak.com/video1.html and see one way of veneering a raised panel in a vacuum bag.
http://http://www.qualityvak.com/video1.html
