Wood NetWork
Excel fraction w/ "
6/26/15
luke Member
I've been searching google all day and I am not finding what I need. Excel is so close but so far...
I'm looking for a way to key a value into a cell and have the result in that same cell be a fraction, properly reduced but displayed with precision up to 32nds and has the inch mark.
I know the answer is out there but can't find it.
Thanks in advance
6/29/15       #2: Excel fraction w/ " ...
B.H. Davis  Member
Website: http://www.curvedmouldings.com
I suspect the heart of the question is the "inch" sign as vs. formatting a cell to a fraction.
If that is the case then post your question over at WOODY'S Excel forum. I've gotten every answer I've ever needed on excel over there.
Wood's Forums
7/6/15       #3: Excel fraction w/ " ...
ranliker
I don't know for sure, but I imagine you would need to concatenate. Probably more than one column needed, with selected columns hid or not in the print area. Perhaps you could also just add a very narrow column with only the inch symbol.
If I remember, getting properly reduced fractions is a bit of an 'issue.' Excel doesn't stick to wordworker type fractions, e.g., 22/25. It's been a long time by I think some multiplying and then, well, I don't remember! But I think google can help on that part.
7/23/15       #4: Excel fraction w/ " ...
luke Member
Excel doesn't stick to wordworker type fractions is the perfect statement. I have googled it to death and continue coming up short.
7/23/15       #5: Excel fraction w/ " ...
ranliker
I'll try to remember on what sheet I've done this and post what I did. It will be a few days though.
8/21/15       #6: Excel fraction w/ " ...
Alan F.
1) format you number to fractions using one of the defaults
2) right click again, format cells, custom
# ??/16"''"
where the text is actually " ' ' " without any spaces, if you want 32's change the /16 to /32
If you want to round up you need to do the round in the format or use a function
Rounding up fractions to neareast denomi
1/3/16       #7: Excel fraction w/ " ...
RobertNH  Member
This is also a very good Excel Help Site.
Excel Help
    Excel Wood Products
