Adhesives
adhesives
11/20/19
GPWOOD Member
I'm in need of a clear adhesive to bond acrylic to lacquer finished wood
11/23/19       #2: adhesives ...
Loctite has a crystal clear construction adhesive that may be worth a test.
12/14/19       #3: adhesives ...
George Member
Check out Roo Clear. You can get the small bottle to test for about $16 on Amazon.
I recently did some testing on Melamine, which is what Roo Clear is designed for. The stuff is impressive. In my tests, I edge glued 2 sided Melamine PB to the face of Melamine. After one day, I popped it off and it tore the Melamine away.
The stuff is awesome. I will use as my main assembly glue for Melamine case goods with dado construction.
You have a different application, but is worth the test. Clean up may be an issue depending on your application process.
