Adhesives
Lacquer thinner on plywood
3/23/20
I am trying to remove some adhesive from good 1 side plywood, I was wondering if using lacquer thinner will damage the plywood?
3/23/20       #2: Lacquer thinner on plywood ...
It shouldn't. I'd start with denatured alcohol first and see if that works. You don't want to soak it. Acetone might be the best solution. It works well to get rid of most adhesives and evaporates extremely quick.
3/25/20       #3: Lacquer thinner on plywood ...
Rusty Statham Member
I use lacquer thinner all the time on UV plywood and never had a problem. I haven't tried to wipe glue, but paint overspray will wipe right off.
3/30/20       #4: Lacquer thinner on plywood ...
D Brown
Sometimes a light sanding will remove the adhesive.
    • CP Adhesives
