Adhesives
Glue up panel, then paint
4/28/20
Jenny
I am trying to produce a painted solid-color wood panel. It is for making drawer front and slab doors of a bathroom vanity. My customer really hates MDF and prefers the drawer fronts to be made of solid wood.
The end product should never come apart and the glue seams between the strips should not show.
I am gluing up multiple small strips of solid rubberwood or other cheap hardwoods to make one big solid wood panel. Each smaller strip is 32 inches long and the width of each strip is between 1.5-3 inches.
I will cut the doors and drawer fronts out of this panel. The doors and drawer fronts will be finished with solid-color 2K Poly.
Questions
1. Does it matter if I glue the strips up vertically or horizontally?
- since we are painting the doors and drawer fronts with solid color, we do not need matching grains. No one will see wood grain
2. Does it matter if the strips have different widths?
3. Is there a particular kind of glue I should use for this job?
4. What would you do to produce a solid-color solid wood panel that don’t come apart or have seams showing?
4/29/20       #2: Glue up panel, then paint ...
rescraft
Assuming they will be 3/4" thick, keep an eye on RH before, during and after glue up. Avoid glue line telegraphing by waiting a day or two before machining, like Leo G recommends.
4/29/20       #3: Glue up panel, then paint ...
JM
I would educate my customer and use MDF.
4/30/20       #4: Glue up panel, then paint ...
Should be fun if you are trying to get a nice slip joint with the panel tongue/slot.
    • CP Adhesives
