Adhesives
Glue up Techniques Needed
7/27/20
Brian Patterson Member
I’m trying to glue up a return trim on a table top and cant think of a good way to clamp for a nice, snug fit at the joint. Anybody know the trick to this? Many thanks in advance...
View higher quality, full size image (2954 X 2157)
7/28/20       #3: Glue up Techniques Needed ...
Not overly difficult? Spline, dowels, biscuits, domino, alternating clamps?
7/28/20       #4: Glue up Techniques Needed ...
Josh Koschak
If the cuts are straight and the dry fit is good, you can use clear packing tape and glue it up as a miter fold then use more tape for the clamping pressure.
Another option would be to first use dominos or biscuits to register the cap in place and then use tape or clamps.
7/30/20       #5: Glue up Techniques Needed ...
Jim Member
Peck Tool miter clamps.
8/1/20       #6: Glue up Techniques Needed ...
Biscuits for alignment and stability. Then pipe clamps on the long run and squeeze clamps on the short run.
Packing tape and biscuits works if the joints are really good.
9/20/20       #7: Glue up Techniques Needed ...
pat s gilbert
Glue size would help
Clamex
    • Supergrit Abrasives
    • CP Adhesives
