Adhesives
Diluent for pressed wood glue
8/30/20
Arth3k Member
Hello everyone,
I'm trying to find a Diluent to get rid of a glue that is used in making pressed wood plates.
Pressed wood is any engineered wood building and furniture construction material made from wood veneers, wood shavings and particles, sawdust or wood fibers bonded together with an adhesive under heat and pressure. This glue is liquid in it's initial state, it passes in a device that sprays it onto the wood particles, after that the wood goes into a compression machine where is cured with high temperature and pessure.
What i'm trying to understand what type of glue is this, a glue that can be cured with temperature and pressure. If someone can explain i to me or has any documentation that i can read about the family of glues used in pressed wood industry. Ultimately i'm looking for a dilluent to clean the solidified glue.
9/2/20       #2: Diluent for pressed wood glue ...
You are looking for a solvent. It needs to dissolve the glue after it cures. Diluents also know as thinners are things like water in ordinary wood glue.
There are three basic solvents that are typically tried on any product. Water, alcohol(denatured) or acetone.
    • Supergrit Abrasives
    • CP Adhesives
