Adhesives
Adhesive Testing
6/14/21
Kabeer  Member
Website: http://www.wifpla.com
Hi
Can anyone advise me that how can I test my adhesive's bonding strength in my factory itself, which I am using for my joinery application, like table top, chairs and other wooden furniture.
Is it right way if I will laminate as butt joint some lumber and submerge in water for overnight, to see the bonding of adhesive or any other best idea?
6/14/21       #2: Adhesive Testing ...
Jeff Pitcher
Hello,
The best way to test a glue joint is to allow the glue to cure for 24 hours and then chisel the joint apart. If everything has been done correctly you should have 100% wood failure. A proper glue joint will be stronger than the wood. If you are testing water resistance, you can soak the piece overnight and then chisel the joint. If you don't require water resistance or if the glue you're using isn't a water resistant glue then soaking it wouldn't really indicate anything. Hope this helps.
6/17/21       #3: Adhesive Testing ...
We take 1 x 4 (3/4” x 3 1/2” maple and glue up a couple of samples of edge and butt joints. Let them cure over night.
Clamp them to a bench with the glue joint overhanging and unsupported. Take a hammer or mallet and give it a good smack. The wood should break next to the glue joint on the edge samples. In an ideal glue the edge grain will stay bonded to the end grain and it will break along the grain. Most glues will get 50/50. Meaning that some of the wood will stay bonded and some will not.
You can likewise do mitered joints. That’s good for comparing things like wood glue and epoxy.
    • Supergrit Abrasives
    • CP Adhesives
