Adhesives
3m NS920 contact adhesive
12/8/21
Ian Member
Hi all!
Long time lurker first time poster:
Does anyone have experience using 3m ns920+ on curved surfaces?
Specifically I am laminating a phenolic backed chemetal laminate onto neatform bending mdf. 30” radius at tightest spot.
Thank you!
Ian
4/3/22       #2: 3m NS920 contact adhesive ...
Ian Member
Spoke to a 3m rep and this is fine for use on curved surfaces.
Hope this helps someone in the future. we applied a month ago and it is holding super strong, will report again in case of any failure.
5/10/22       #3: 3m NS920 contact adhesive ...
winlong Member
Website: https://www.internetwoodglue.com/
Why doesn’t hot melt glue stick? It can be analyzed from the following four aspects: 1. There may be problems with the quality of the purchased hot melt adhesive If it is caused by quality problems, you must find the corresponding supplier for accountability. When purchasing again, please choose a hot melt adhesive manufacturer with strength and quality assurance.
2. Debonding or non-sticking due to incompatibility of hot melt adhesive with material Check for incompatibility with the type of hot melt used for the composite. If it is caused by the compatibility of the material, you only need to re-select the hot melt adhesive that is compatible with the material. It is very important for users to test and proofread well before mass production!
    • CP Adhesives
