Subject: Re: enclosures for photography dark room
4/19/14
correy smith
Hey guys, I have a job that I am rolling around ideas for.
It's a good client's dark room in his house he is currently building. His GC spec'd sliding panels on one end and I have previously been in talks with Mr.G about door set #1 which were hinged double doors.
The customer expects air tight and light tight. He will be running an AC and needs near absolute darkness.
Hinged set,
he does like metal hardware and would like "big wooden trowel handle shaped handles" So maybe I just grind of the blade of a block trowel and set a cuople screws in it.... LOL jus kiddin' But still leaves the issue of how the doors will stay closed. I offered I would look into magnets with the passive door with head and toe bolts.
I intend to make a double reveal on the lap between the two to kill the light but still need a sweep that will hold out light and may be some weather strip of some sort, but unsure if that adds or detracts from the ensemble.
Thanks for any thoughts on that.
Further door set 2 is the sliders in pocket framing. They are freaking big at 2.25x42x96 in Monkey Pod which weighs about 4.5#/bft. Same criteria as above for light.
My initial thoughts are to have a type of T&G joint at the mating edges and make the doors an inch or two wider so they still go in a bit past the jambs when they are closed.
You would think they need to be bottom bearing but may be sweeps will work here as well. The floor is concrete with a vinyl covering so bottom track profile if any will need to be low and easy to walk on without shoes.
I need to source the hardware for this as well. It was kinda just dropped in my lap as I only thought I was making the hinged set.
The sliding hardware needs to be exceptional in every way. I do not have any real preference as to top or bottom bearing it will , I assume, depend on the individual system and the ability to incorporate a form of sweep that will meet the criteria for light.
Thoughts on hardware?
Large door size magnetic latches???
Thank-you for any leads and thoughts.
Have a great Easter weeekend,
best , Correy
4/19/14       #2: enclosures for photography dark roo ...
Alan F.
Something like this:
and this
http://static.bhphoto.com/images/images500x500/204410.jpg
4/19/14       #3: enclosures for photography dark roo ...
Alan F.
try this
View larger image
4/19/14       #4: enclosures for photography dark roo ...
Alan F.
and this
View larger image
4/20/14       #5: enclosures for photography dark roo ...
correy smith
Thanks Alan, that's kinda what I was thinking but with solid wood.
I just read my original post, I must say I was still a bit a sleep when I wrote this morning. I meant to say.....
Hinged set,
he does NOT like metal hardware and would like "big wooden trowel handle shaped handles"
5/14/14       #6: enclosures for photography dark roo ...
Jim Lewis
I just made myself a slider. After much consideration and a post or two here, I went with bottom track and sheaves from Outwater Hardware. I put the link below, FWIW the paper catalog was much more helpful— my track shows up on this page but not my sheaves. There's a flat "W" style track with capacities up to 200 lbs.
I got Q-lons from A&B Building Supply. They have many styles of brush and foam weatherstrips. Due to friction, you may need to do something intricate with tapered trim to allow the door to slide freely until it's fully closed. Think fire doors in old warehouses, with the angled track. Light tight is more difficult than airtight, which was my issue.
I had difficulty researching their website, but as I ordered the owner tipped me off: he has links to manufacturer's catalogs on the front page, they are much easier to search.
My experience: weatherstripping a sliding door is more or less uncharted territory. You will find a lot of hardware but it is hard to get good, experience-based advice.
Outwater (Richelieu) Hardware
5/15/14       #7: enclosures for photography dark roo ...
correy smith
Jim Thanks for the helpful links and the insight.
The builder has already installed his preferred closure system and I only have to provide slabs for him to hang.
Thanks again.
