Subject: Re: Reducing Power Feed Speed
7/17/19
Gary
I have a Holz power feed that I need to slow down for certain runs. I am looking at changing the gear sizes to accomplish this. Has anyone tried this?
Is a motor/speed controller an option?
Thank You
7/18/19       #2: Reducing Power Feed Speed ...
With smaller feeders that's exactly the way they are designed to change speeds. They usually come with 4 gears which give you 4 speeds.
If it is a 3 phase unit you could slap a VFD on it and change the input frequency and adjust the speed within the speed adjustments it already has on the switch.
7/18/19       #3: Reducing Power Feed Speed ...
KCR
I have 2 feeders of different brands and they both run 4 ft./min. at their slowest speed. I'm just curious, how much slower than that do you want to run?
7/18/19       #4: Reducing Power Feed Speed ...
MarkB Member
Wow, I wish my 4 speed feeders would go down that slow (rarely). We have two 4 speed 1HP 3 wheel feeders with swapping the gears to get between the ranges and the slowest feed speed possible is 13fpm (13/36 and 43/108). We run Comatic DC feeders on shapers and they only go down to 7fpm.
