Subject: Re: Louvre hardware
Louvre hardware
8/7/19
Andy Member
I'm quoting some custom doors and the architect wants the best possible movable louvered because of the exposed location. I've made louvered openings many times but only with the stick. I need something that screws open and closed much like a glass louvered window. I've seen them use in the islands and made of brass. Does anyone know where I can source this hardware???
8/25/19       #2: Louvre hardware ...
Craig Caughlan Member
Website: wetimber.mx
Although I've no experience with plantation shutters, we're investigating. You might checkout:
http://www.naco.it/web/
Look at their Catalogo Legno. Rangate makes a cutter for their PL70:
https://rangate.com/products/shutter-cutter
I'd be curious to know what other options you might come up with. Cheers
8/27/19       #3: Louvre hardware ...
Mitch Suber Member
In 25 years of making operable louver Shutters, I have never see a supplier for the hardware you mention. I have seen crank mechanisms to move the panel, only in pictures though. If you had to fashion some type of mechanism, it might be simpler to start with a hidden tilt rod. When you say exposed, will they see exterior use.
8/27/19       #4: Louvre hardware ...
Andy Member
Mitch if you follow the link Craig put up in the previous answer you'll see some excellent examples of what I'm looking for. I'm going to contact the company soon. There are lots of companies that sell the mechanism for 4 inch glass or wood. I'm matching existing so I'm trying for find something with 2 inch louvers and hopefully brass or bronze. And yes these are exterior doors and windows.
