Subject: Re: QS White Oak counter top?
12/1/19
Keith Newton
If you had a nice stack of 12" ~ 16" wide QS and rift W Oak lumber, and a client that wanted you to use some for their kitchen counter tops. Would you want to rip it up, then glue it back together, because that's what their interior designer suggested.
Or would you rather just use two book matched boards glued together for the counter top?
12/1/19       #2: QS White Oak counter top? ...
Charge the appropriate amount and cut it up. Make hay while the grass is growing.
12/1/19       #3: QS White Oak counter top? ...
QS? I'd glue it up and keep the character. If it's flat to begin with it should stay that way. I've never had much problems with properly dried wood of any sorts (hardwood) keeping it full width.
12/1/19       #4: QS White Oak counter top? ...
Pete
I just did one for myself from 12 foot tiger maple. Its three boards, 8/4 to start. I did not intend for it to be tiger, nor did I pay for it, but my supplier sent it so I couldn't rip it up after seeing the grain. I might worry more on the thinner stock moving but rift oak may not move to much. I would charge accordingly and do it. The open pore wood on a countertop may worry me if it isn't filled. Not sure if that would cause issues or not.
12/2/19       #5: QS White Oak counter top? ...
Buy some rift for the cut up countertop - I assume a 'butcher block' look.
Then sell them a nice table using the matched wide QS Oak. Might use a little gentle education about the rarity of wide QS, bookmatch, etc. Involve the designer. Maybe even start there so they can get in on 'designing' the table.
12/2/19       #6: QS White Oak counter top? ...
D Brown
Typically I would say that more narrow boards may stay flatter opposed to a few wide boards. The seasonal movement will be the same. Honestly it depends on the actual look desired, the designer may want a butcher block multi piece look. You will be using the same amount of wood regardless.
I would suggest showing the material to the designer and home owner and let them decide and charge accordingly.Good luck.
12/2/19       #7: QS White Oak counter top? ...
Keith Newton
If I have to cut it up just to feature glue lines, I would buy and use plain sawn WO, so it would be QS and rift after I flipped and glued it back up. Or better yet I would just buy it off the shelf.
12/3/19       #8: QS White Oak counter top? ...
D Brown
Keith, I should have said a random planked look not a butcher block look.
12/3/19       #9: QS White Oak counter top? ...
Don’t waste good material on customers who don’t care. Just because you & I think it looks better & proper, doesn’t mean it’s the correct use of a more expensive finite resource. Buy some new stock. Rip it up and give them as many glue lines as they request. Their job gets done. You get paid. You’ve still got some nice wide qtr white oak on your shelf. It’s one of my favourite woods. It should not be wasted on people who don’t appreciate it.
12/9/19       #10: QS White Oak counter top? ...
Kostas Nikolaou Member
Look, being in the millwork shop drawing business - we get a lot of non practical direction from our clients. What I tell my draftspeople and PM's is this .
- We have a responsibility to bring up proper value engineering methodology and techniques to our clients and advise them of the options. If after this - they choose to ignore or just pain "choose" their original instruction , then we ( and in this case you ) would not have any other option but to follow their lead.
Just saying ...
