Subject: Re: Optimal Joint Method for Making Curved Beams
2/2/24
Kevin Taylor
It was brought up in a post about hay barns built with laminate arch beams. My grandfather built his dairy barn in this manner with plans from Michigan state college agriculture engineering dept. I have some drawings somewhere.
The arches were laid out on the floor of the barn, and 1x3 Were nailed in layers, no glue. This barn was 4 layers of 1x3. Larger wider barns took more layers and 1x4.
2/2/24       #2: Optimal Joint Method for Making Cur ...
WLeach Member
Well, I know how the " Dome Room " roof at Thomas Jefferson's Monticello was constructed. The Structure is made of laminated white oak, each rib is four layers of 1 inch thick material nailed together using clinch nails.
2/2/24       #3: Optimal Joint Method for Making Cur ...
WLeach Member
This is a 1/4 scale model I built for the visitors center showing the construction
2/5/24       #4: Optimal Joint Method for Making Cur ...
Will Williamson  Member
I studied, just such a barn, that Kevin describes, in Lapeer county Michigan several years ago. I often have thought, that I mite one day, use that method to build a barn. I had forgotten about it till today. It looked like they used 1 x 4 x 20 foot green ash for the rafters. they were set, into shallow mortices on top of an 8x8 top beam. I discussed that method on this forum years ago. did you find a set of plans
