carved panel
9/18/17
macks Member
I'm collaborating with a carver to build a door. I'm building the door and panel separate, giving him the panel to carve then installing it in the stile and rail door. He wants 5/8" solid wood to carve his relief on each side. Can I laminate this onto plywood?
9/18/17       #2: carved panel ...
John Member
No. Solid wood that thick needs to be able to expand/contract with changes in humidity. If you glue it onto plywood it will split when the RH changes enough.
Why were you thinking of gluing it onto plywood in the first place?
John
