Wood door with formica
2/4/19
Alexi Member
Hi all hope ur having a great day
I dont know if this the right forum to post my msg but if any one can help this will be great
I have interior door to make for a hospital
They requested that the door are made from mdf toped with 1 mm formica
I have a press that can be heated
Should i use the same glue as veneer that work with heat or should i cold press them with white glue
Anh tip will be much appreciated
Thank u all
2/4/19       #2: Wood door with formica ...
Use your standard PVA glue. You can hot or cold press - it will not affect the Formica. Just be careful of scratching the laminate when loading and unloading the press.
2/4/19       #3: Wood door with formica ...
Alexi Member
Thank u i will try it
May i ask i have to add to this door stripes of stainless steel how can i sttach this to the mdf
2/4/19       #4: Wood door with formica ...
Epoxy would be your best bet choice I think. Protect your platens in the press with plastic sheets(vapor barrier) so that the epoxy doesn't stick to them. You can warm the press to 40 Celsius to accelerate the cure.
Scratch the back of the stainless steel with sandpaper to improve the bond.
4/1/19       #5: Wood door with formica ...
Kostas Nikolaou Member
Website: http://zdraft.com
Everything was fine until I read the part about the strips of stainless steel.
Even with the great suggestion of using epoxy, the following problems still exist.
1 - If the stainless strips are too thin , then you will have warping ( or telegraphed wrinkles) on the face of the stainless the moment that door is exposed to a quick temperature change. ( ie , air-conditioner on too high )
2 - The stainless strips should not be "sheered" by the manufacturer. This will cause a twisting in the material that will eventually start to show by starting to want to curl back - even after the epoxy is applied.
3 - The only way that I have seen stainless successfully embedded is by using a thicker material that has not been cut via a sheer , and then implanted within a groove with glue on all three sides.
    Doucet Machinery
