Cast or turned Aluminum Moldings
7/22/20
Harold Pomeroy  Member
I need bases for columns. The existing were lead coated White Pine log sections, and lasted 190 years. There is a lead law, and I don't want plastic. Has anyone used custom aluminum turnings for column bases?
Thank you
Harold
7/22/20       #2: Cast or turned Aluminum Moldings ...
I have not seen cast or turned aluminum, but I have made many column bases over the last 50 years. Some new, most replacements.
We will often use 1/4" or 3/8" aluminum plate to make four feet and vent holes in the rectangular base. Normal columns (not logs) are open all the way to the top and can breathe thru thermocirculation. The aluminum gets the base up out of the water, and keeps the air moving. Overzealous painters like to fill the air gaps with caulk.
Of the 20 or more of these jobs I have done, I drive by two of the earliest, and they still look good. Honduras Mahogany, made into 6 pc rings with splined miters and epoxy, then turned on the lathe, then stacked and screwed with stainless screws. I recommend the plinths with aluminum.
7/22/20       #3: Cast or turned Aluminum Moldings ...
Keith Newton
NO, but when I make them for the homes in my historic neighborhood, here are a few things I do.
Usually I choose Spanish cedar since it's the best most durable / available wood that I have to choose from. Then I make Octagonal rings that I stack to get the height. I start by making half rings which are easy to glue up, then cut the ends on TS sled to get it straight across, and then glue the halves together. This is much easier than trying to cut 16 perfect angles.
Each of the 8 mitered pieces have a notch cut about 1" back from the toe of the miter for the hand-screw clamp to close the miter, then a bar clamp across the halves to close heels lightly.
I use epoxy for the adhesive. Then when everything is glued up, turned and sanded, I use the Smiths CPES epoxy to seal it all up. I keep adding it as long as it continues to penetrate. I may go ahead and prime them too before sending them out.
I have nothing to do with the above company, except for being a happy customer. It was made to soak into decayed wood, but works great on new wood going out into the harshest environments.
Oh, and one final tip. When I glue the ring stacks together, I don't stagger the joints by half way in between, I may only shift them over by 1.5' to 2". When they are shifted by half, and movement from MC change is greater and is harder on the glue-line. Keeping them closer in alignment prevents the shear between layers.
Harold, one of the houses up the street from me got some new cast concrete bases that were about 2" larger than needed, which left a 1" flat around the top. I don't know why the customer accepted that, or why they didn't add another ring even if it was just a square fillet to split the difference, but it sucks to may eye.
Be sure to use the CPES to soak the bottom ends of the columns above to prevent them from soaking moisture up.
I know I didn't answer your question, but maybe gave you something else to think about.
7/22/20       #4: Cast or turned Aluminum Moldings ...
Thank you for the resposnes.
I should have said that the turnings have 8" hollow centers.
The aluminum plate and stacked laminations both sound good. The originals have 6" thick walls, and end grain on the top, exposed, surface. Having long grain presented to the weather is about the best option.
Clamping with notches, in steps, sounds good. In the past I have used ratchet straps.
7/22/20       #5: Cast or turned Aluminum Moldings ...
The aluminum would seem a bear to keep finish on over time especially down near the ground.
Not sure your aversion to plastic, I love the purist passion for wood but sometimes times change. Historic aside there are a lot of other options. I love wood and lament the changing times but there is a reason we dont make spoked wooden automobile wheels anymore.
7/22/20       #6: Cast or turned Aluminum Moldings ...
TonyF
Harold:
You might consider black locust as a suitable material. Before the advent of pressure-treated lumber, it saw a lot of use here in the East as fence posts. I would think that any wood that you can bury would do well above ground.
I don't know where you are or how much material that you need, but the source below has some available.
Hope this helps. TonyF
Robi Decking
7/22/20       #7: Cast or turned Aluminum Moldings ...
Any machine shop could turn billet aluminum into a column base. Powder coating would last a long time. There is a wide selection of square and round columns available. Either load bearing or decorative.
Superior Aluminum
7/30/20       #8: Cast or turned Aluminum Moldings ...
Thomas M Diel  Member
Website: http://thomasdiel.com
I'm sure your aware but if you go with aluminum make sure you use a self etching primer made for aluminum or metals in general. Even if painted on a fresh surface aluminum will oxidize over time and regular primer and paint will flake off.
