Production shoe moulding
3/24/21
Mark Slocum Member
Looking for ideas on best setup to run shoe moulding on a moulder. Material will be red and white oak, hickory and walnut.
3/24/21       #2: Production shoe moulding ...
dustin orth
How many LF at a time are you talking about and what kind of moulder do you have?
3/25/21       #3: Production shoe moulding ...
Mark Slocum Member
Wadkin 5 head. Over a 100k linear feet per month.
3/25/21       #4: Production shoe moulding ...
Dustin orth
I remember seeing a tool that had both a flat knife and a saw blade for splitting on the last bottom head, then you would use a top head head for cutting multiples side by side. Call Global Tooling out of Oregon, thats where I saw that setup. Can you fit an anti kickback on the front of that Wadkin?
3/26/21       #5: Production shoe moulding ...
Mark Slocum Member
Would this idea be a possibility? Top head profiles the moulding but leaves say 1/8" or wood left on the bottom. Then the last bottom head is a spiral and it removes said 1/8" or remaining material. Thus leaving you with individual pieces.
3/27/21       #6: Production shoe moulding ...
dustin orth
Its feasible to do it that way. I haven't tried it myself though. Would just need to make the outfeed bed be higher either thru a shim or such. I think the profile would need to be ground so they are all facing the same way. With a splitter blade on the last bottom, you would not be milling a straight shoulder with the top head. I would grind that so 2 pieces are back to back, then the saw would split them apart. Definitely like the idea of leaving more material and having the last bottom take it off.
4/7/21       #7: Production shoe moulding ...
Russ
Website: http://mr-moulding-knives.com
Mark
This is a way you can mill it in large volumes. We always suggest having an antikickback device while machining multiples. The profile cuts thru the wood and past it by .005" - .010" depending on what the client feels most comfortable with. The last bottom has a .020" shim under the bedplate, which will remove .020" of material, then you have twice the production in half the amount of time.
See pdf below
Good luck
Hope that helps
Russ
BASE_SHOE_P563.pdf
