Power feed Mounting
8/15/21
I got a great deal on a Bridgewood 3hp shaper. They are a decent small machine. I used to own one back in the 2000's.
I need to mount a 1hp 3 wheel Comatic power feed. The mounting plate doesn't have leave much room on the rear corner of the table. Those shapers use one of the fences off of the bigger shapers.
My question is if I make a mounting plate that would be made of steel c-channel do you think it would be fine if I bolted it to the back of the table?
Those are heavy machines. The power feeds aren't that heavy. Even when you swing them out of the way. Its moving the mounting location 4" back. The 1/2" bolts won't shear. The machine shouldn't fall over. Am I missing something.
8/16/21       #2: Power feed Mounting ...
Mark B
I know from experience cast iron is much stronger than Ive always thought but if your bolting to the table, and going to be cantilevered, Im always cautious but a lot would be a judgement call on the thickness of the casting and the webbing below. Theres a lot of leverage on a feeder though a 3HP machine would assume its not going to see monster work. My fear has been if it gets in a bind, or someone does something stupid and snap the corner of the table off. Had a scenario in my shop where a guy trying to go too fast got a board on top of an auxiliary fence and I watched the feeder stand cant over so far as I was running to shut the feeder down that Im shocked the table didnt snap but we had through bolted feeder mount to a steel plate we installed below the table because the casting seemed too thin when I mounted the feeder.
Good heavy table I'd imagine no issue but only you can see the mounting point.
8/16/21       #3: Power feed Mounting ...
Mark
I've used a 3/8" (+-) steel plat to cantilever two of the power feed base bolts off the table with two going through the plate and the cast iron top ; I also bolted the plate to the table in two other places with smaller bolts. But if you're going to hang off the very back edge, I'd suggest a couple diagonal braces bolted to the cabinet also
8/16/21       #4: Power feed Mounting ...
I'm thinking that a better solution would be to make a T section. Weld a piece of 3/8 plate to the underside of of the large piece. That way I can fasten to the top and the edge. (2) fasteners in each.
8/17/21       #5: Power feed Mounting ...
Bruce H
I'd fasten the sub plate to the shaper table top and the cantilever part to the base of the machine. That will take some of the stress off the cast iron table.
8/18/21       #6: Power feed Mounting ...
Adam Spees
I ended up fastening half of the power feed base to the table. The other half sits on a piece of 1/2" angle iron that is bolted into the side of the table. It actually saves a fair amount of space.
