Silicone for bedding IGU
2/4/22
Zach Member
Just wondering if anyone can recommend a silicone for bedding insulated glass. I prime my doors and windows before setting glass, and find that silicone peels right off the primer. I let the silicone cure for 10 days. It sticks great to the glass and bare wood, just not primer.
Thanks in advance for any suggestions.
Zach
2/4/22       #2: Silicone for bedding IGU ...
Mark B
I think if you search the archives on the subject you will find that RTV is a bit of a go-to as your main concern is that whatever you use doesnt attack or adversely react with the sealant in the IGU itself. Search the forums and knowledge base and you'll likely find all the information you need.
2/4/22       #3: Silicone for bedding IGU ...
Zach Member
I have seen the recommendations for RTV in previous posts. I was more curious about specific brands/ products. I'm hoping to avoid buying too many different ones just for tests. I know CRL and Dow Corning make RTV. Can anyone speak to how well they stick to primer?
2/4/22       #4: Silicone for bedding IGU ...
I'd ask the glass supplier what they use so it's compatible with the glass seal.
2/4/22       #5: Silicone for bedding IGU ...
Mack s Member
We use pecora 895
2/7/22       #6: Silicone for bedding IGU ...
Harold Pomeroy
Like RichC said, talk to the glass supplier.
If you have incompatible sealant, the seal on the insulated glass can melt, and the sealant can ooze into the site line. Even if the client doesn't notice the ooze of black death, the fog that follows is truly noticeable.
This happened to someone I know.
2/7/22       #7: Silicone for bedding IGU ...
Zach Member
Mack, thanks for the suggestion. I'll look into that.
Rich and Harold, I will be sure to check with my vendor as well. I've heard of the seals being compromised, but never heard about the black ooze. Interesting.
2/9/22       #8: Silicone for bedding IGU ...
Apply the RTV to bare wood, before finish. We find it has enough adhesion to be nearly a structural member of the assembly. Doing it after prime, if it doesn’t
stick, is no good.
Whatever you settle on, check compatibility.
We use the RTV as mixed up by American Sealant in Ft Wayne, IN. It does leave a bit of - something - behind, hard to clean 100%. That is the only drawback, and not directly our problem.
2/10/22       #9: Silicone for bedding IGU ...
Zach Member
Thanks David. I'll call American Sealant. Maybe they can answer some questions on adhesion. I agree that it would be bad if it doesn't stick to the primer. With some luck, maybe I can find a product that will stick. (and is compatible) It just makes life much easier to spray prime sash before glass. The search continues...
