Subject: Re: utility plywood
utility plywood
11/30/17
sean foo
What are other shops using for utility grade plywood? My issue is that I can get a decent plywood at home depot for $30 with a reasonably nice pine face and good core. But I hate taking the time to go pick it up.
My hardwood suppliers can get me a pine plywood for the same cost, but it's much worse quality. To get the same quality, I've got to spend in the low $40's.
11/30/17       #2: utility plywood ...
EDDIE Member
Is it really less money? Who's paying you to go get it. Handle it 3 or 4 times. What's not getting done at the shop?
Figure this out. Run the numbers and see if it's less money. In my case it would be more expensive.
11/30/17       #3: utility plywood ...
sean foo
Eddie,
That's my whole point. I'm hoping someone would chime in with a plywood they get from their supplier in the $30 range that is comparable to what I have to drive to HD to get.
12/1/17       #4: utility plywood ...
MarkB Member
have it delivered
12/1/17       #5: utility plywood ...
Andy
I just loaded up 20 sheets of the same stuff a week ago and was thinking that HomeDepot could probably deliver it for free.
12/1/17       #6: utility plywood ...
HD may use the material as a loss leader and not want to sell volume?
12/1/17       #7: utility plywood ...
Andy
I was thinking the same, definitely a loss leader just like the 2x4’s. Our local hardwood suppliers can’t match that price. The units of ply are placed literally in the isle by the roll up door/contractor check out area.
12/2/17       #8: utility plywood ...
Buying less than a unit at a time is always going to cost more from the distribution yards. You aren't valuing your time! HD has delivery service!
12/6/17       #9: utility plywood ...
B
We use 1/2 and 3/4" BUL. Aspen throughout. It's like cdx but has 1 sanded face so it holds on the cnc. 20-30 dollars/sheet.
12/6/17       #10: utility plywood ...
sean foo
That's interesting.
What is BUL? And where do you get it from?
12/7/17       #11: utility plywood ...
B
I think BUL stands for b-face, rated for underlayment. Not exactly sure. We get it from cedar creek. Theyre a national lumber supply chain.
Oddly, where the plywood is made is closer than cedar creek, but they only sell it by the semi load.
12/14/17       #12: utility plywood ...
Pdub
That sounds like a good product for toe boxes. we have a helluva time finding reasonable material that will stick to the CNC and cut small parts.
You say it's like CDX? Does that mean it's waterproof (resistant)?
12/22/17       #13: utility plywood ...
B
Not sure about the water resistance. I doubt it is - I never thought cdx was water resistant either.
This is the company that makes it:
http://bessemerplywood.com/
1/3/18       #14: utility plywood ...
Pdub
Thanks.
From my understanding, the "X" at the end of an plywood nomenclature stands for eXterior glue.
