Metal working in a wood shop
11/4/16
How many of you have some metal working capabilities in your shop? I'm now semi-retired and have often thought I'd like to be able to make things in metal. I'll soon have more time as I've turned over running the business to a younger man. I've had a milling machine (Jet 9x49) for a couple of years, just added a new lathe (PM1440HD), have a melt furnace with a crucible that holds 10#s of aluminum (about 100 cu. in.). I've been casting aluminum for about 6 months, going quite well. Easier than I had thought. Training is via YouTube U.
The CNC router actually does pretty well on aluminum but our software isn't ideal.
11/4/16       #2: Metal working in a wood shop ...
Pete D Member
I got into metalwork a little over a year ago and love it! I have a separate shop where I fabricate all the metal components and like keeping the wood and metal separate but you could certainly do it in the same space if needed. All my work is with furniture bases, frames, etc and wish I got into it sooner. It opened up a new world and way of designing and working because of the aesthetics and structural strength of metal. I work mostly with cold rolled and stainless, have done a little with aluminum. I've got a mig & tig welder, plasma cutter, Bridgeport, cold saw, horizontal bandsaw, tubing roller and a variety of grinders/buffers. If you're not already familiar with: http://www.practicalmachinist.com/
It's an incredible resource, similar to woodweb for metal.
11/4/16       #3: Metal working in a wood shop ...
Have you talked to your insurance agent Larry? Metal working is one thing, a crucible is quite another. Biggest deal with metal working machines near woodworking is dust! A nice layer of way oil on a metal lathe or mill ways, will turn to a gummy mess when a fine layer of wood dust is added.
11/5/16       #4: Metal working in a wood shop ...
Hen Bob Member
We too have a metal working shop, but in another building from the woodshop. It's a huge benefit to be able to fabricate parts in house. I also agree that wooddust and metalworking equipment don't mix well. Same goes for cutting oil and shavings near a raw piece of wood that needs to finished...
11/5/16       #5: Metal working in a wood shop ...
Rich, No firing or welding is done inside the building. I have a small MIG welder. My metal working is in a separate part of the building. Pete, I log on to practicalmachinist.com but rarely comment. A great site is myfordboy.com Also on you tube under myfordboy. Nothing to do with cars, Myford is a British made lathe. If I ever get the time I'm going to setup a small anodizing system. I'm busier now that I'm retired! Or is it just that I'm slower now?
