Subject: Re: Need euro hinge recommendation
7/5/15
cabmaker
I generally use blum hinges but find myself needing something that will overlay the box farther than usual.
Does anybody know of a hinge that will overlay 2 mm past a piece of 19 mm plywood? I am looking for a total of about 21 mm though could go with 20mm if necessary. I would still like some ability to adjust the door laterally if possible so I don't to have to use all the adjustment at the getgo.
If possible I would like to be able to drill for these hinges with a Blum 3 hole press. Would be great if I could get a insertion adapter but can just tap the hinges in if need be.
Any ideas where to get this hinge?
View higher quality, full size image (2200 X 1754)
7/5/15       #2: Need euro hinge recommendation ...
cabmaker
Picture didn't take
this is what I am looking for
7/5/15       #3: Need euro hinge recommendation ...
eddie
blum 73b3580.
Listed at the top of the page. It says up to 22mm overlay.
Down in the boring chart it only lists 20mm overlay. With a 0 plate. You might get this to work. It also is an inserta hinge. No insertion ram needed.
7/6/15       #4: Need euro hinge recommendation ...
Here are the maximum overlay possibilities for Salice hinges when using a full overlay hinge and a 0mm mounting plate with the edge bore distance (K) shown.
94 degree hinge: 24mm overlay, K=9mm*
110 degree hinge: 21mm overlay, K=6mm*
120 degree hinge: 21mm overlay, K=6mm
165 degree hinge: 24mm overlay, K=9mm*
94 degree F Series: 34mm overlay, K=15mm
* Indicates a soft close option available.
7/6/15       #5: Need euro hinge recommendation ...
cabmaker
Thanks guys.
I will look into all of those options.
7/8/15       #6: Need euro hinge recommendation ...
Henk Cusveller Member
did you check the Hafele catalogue/ website? they have tons of hinges. Hafele.com/us Depending where you are of course. Like the idea, looks neat. Good luck
7/9/15       #7: Need euro hinge recommendation ...
Henk, Hafele is a Salice distributor.
