Subject: Re: Bracket Feet
Bracket Feet
9/23/15
Calvin Williams
Website: http://www.williams-woodshop.com
I have a design situation on a job I'm about to start. There's probably a really simple solution and I'm sure I'm just overthinking it.
I have a cooktop cabinet and the designer wants to do pull out fillers on each side as well as bracket feet on the cabinets. I'll attach a picture of the look that I really like. It looks like it is going to interfere with the pull out as the feet will stick out past the side of the cabinet. Not sure if I need to put a small filler in so it will clear the bracket feet and not sure how appealing this will look either.
Also, is there going to be too much going on between the bracket feet, decorative corners and the fillers that will have half columns attached to them? Any suggestions are appreciated. Thanks.
9/26/15       #4: Bracket Feet ...
mike Member
Wouldn't the pull out ride above the feet similar to were the doors are now? If not make so.
9/27/15       #5: Bracket Feet ...
Calvin Williams  Member
It's a pull out filler with a half column attached to the face. So, it is 34.5 tall. I decided to just cut out my own bracket feet. Thanks for the response.
