Subject: Re: flip up door hdw
flip up door hdw
9/24/15
Tony
I have a job coming up soon that will require an appliance garage under a standard wall cabinet (not in a corner). My customer has sent me pics of a few different options. We have always used a tambour door in this situation but I think she is leaning toward a pull out/then up type door. It is not a pocket door, but pulls out and up out of the way. I have a pic and will try to upload it if I can but seldom have any luck. I would appreciate any suggestions/options you may have. Thanks
View higher quality, full size image (422 X 634)
9/24/15       #2: flip up door hdw ...
Andrew J. Coholic  Member
Website: http://www.joecoholiccustomfurniture.com
Used the Blum (Aventos I believe) lift up door hardware. Very slick. There are 5 choices depending upon the door size and weight.
We used them for covering Micro wave ovens in a pantry.
9/25/15       #3: flip up door hdw ...
Dan
We find the "Free-UP" from Hafele to be an excellent choice for this application. Similar to Blum with weight choices.
9/25/15       #4: flip up door hdw ...
Dennis Bean
The parallel Lift from Salice is easy to install and is offered in a kit form complete with a mounting template.
There are 3 items to order: (1) Lift kit, (2) Piston based on the door size and weight, (3) Stabilizer bar which is can be cut to the width of the cabinet.
This illustration shows a "long arm" lift which permits the door to completely clear the cabinet opening.
View higher quality, full size image (7440 X 2768)
