Subject: Re: Question, sandingmaster convert to 220v
3/10/17
william  Member
Hopefully this is the correct area to post this message, let me know if not.
I am considering buying an older Sandingmaster SCSB 2-1300 (aprox 30 years old). this machine requires 440v. 54amps. I was wondering if anyone has had luck converting a machine like this to 220V 3ph by re-wiring the motors and conveyor speed control. I'm thinking this may be too complex as the control circuit may also need 440V.
I could purchase a transformer, but this is expensive.
Thanks in advance for you help.
3/10/17       #2: Question, sandingmaster convert to ...
No such thing as 440 3 phase. Here are the voltages for 3 phase in the (USA) 120/208 V / 277/480 V / 120/240 V / 240 V / 480 V.
You'll need a wiring diagram, or a volt/ohm meter instead of just guessing what the control circuits are. You sure the motor wiring can't be changed to run on lower voltage? It will say on the motor plate, or under the cover on the wiring junctions. Sounds like you should bring in an electrician.
3/10/17       #4: Question, sandingmaster convert to ...
Dave Adam  Member
Website: creativeconnectors.com
Thanks for your reply Rich C.
Machine is made in Holland and name plate states 440V. Motors can be wired for 220V 3ph, but control relays may need higher voltage, not sure as it is located out of town. and there may be other electrical surprises i'm unaware of. I could determine all issues if i travel out there, but may not be worthwhile. Vendor is not technical.
3/11/17       #5: Question, sandingmaster convert to ...
Bruce Henriksen
Which Sandingmaster machine are you talking about? Model number? Without seeing the electrical plate I am guessing it can be wired and run on a lower voltage. (most can) I would also guess that the control will work. I have a Holland made Sandingmaster 2000 and run mine on 240 volts. Call one of the machinery dealers that sold those machines and ask.
3/27/17       #6: Question, sandingmaster convert to ...
Adam West  Member
The best thing to convert a sandingmaster to is a boat anchor. I'm sad to see so many still around. This is from a guy who's worked on over 1500 sanders in my career.
