Subject: Re: Thermofoil Return at D/W
6/14/17
Randy Stone Member
Website: http://www.dovetailconstruct.com
I'm building a island cabinet with a dishwasher on the end. Its all thermofoil doors and fillers. On the left of the d/w is a FEP with a 1.5" filler on the face. Behind the filler I have a 31.5" x 6" return filler piece so you don't see unfinished cabinet when dw door is open. I just found out that I cannot get a filler smaller than 3" so I will have to rip one out of wider stock. Here's the question, and some of you already know what I'm going to ask. How do I avoid the raw unfinished edge due to the rip? I want to continue the 1/8" gap at the FEP and filler. Do I buy some loose thermofoil and cement it onto the ripped edge of my filler?
Thanks!
6/15/17       #2: Thermofoil Return at D/W ...
Paul Miller
If I understand you correctly, you want a 1 1/2" filler next to the dishwasher and you have a finished end panel on the side that the filler comes up against. And, you have to cut down a 6" filler.
If this is correct: If your end panel is wide enough, I would do a miter fold with the filler and the end panel. Then, you would have a finished end next to the DW.
If you cannot do this, then putting edge tape of a matching color on the cut edge is your best option.
We do a lot of miter folding.
