Subject: Re: Closet doors
Closet doors
11/4/17
scott
We are building a set of closet cabinets with shaker style doors approx. 90" tall and one full length door per section. Question is I would like to use euro hinges and not sure if these are the right application or a butt hinge is more appropriate.Will a 3/4"thick door be ok or should we consider 1"? Thanks for your suggestions.
11/4/17       #2: Closet doors ...
cabinetmaker
@ least 5 hinges 1" would be better, but I just built some for an inset set of cabinets 94" tall had center rail though
11/4/17       #3: Closet doors ...
Derrek
Euro hinges work great, shaker door is very light compared to a full panel or slab door. We would use 3 hinges on this with no problem, associated Ming 24” max width
11/4/17       #4: Closet doors ...
duster
3 hinges should work fine. Making your 90" tall doors perfectly flat will be your challenge.
11/5/17       #5: Closet doors ...
Scott,
Here is a chart for the recommended number of hinges required based on the door size and weight. This is based on doors up to 24" in width. This is from the Salice catalog but other brands would recommend similar. 5 hinges.
Dennis
View higher quality, full size image (588 X 764)
11/6/17       #6: Closet doors ...
Keith Newton
Scott, If you haven't already run into this, sometimes it is pretty hard to get all the hinges to clip when you install, and especially reinstall after the painter.
One thing I've found, is to take the mounting plates off, then hang by the top and bottom, the snap the plate on the middle ones, and open them against carcass and screw them in. Note, you may need to use the in and out adjustments to get them to line up, but that is easier than trying to get the clips to snap when things are off from previous adjustments.
This works for me anyway.
