Subject: Re: Calibrating WIDE BELT sander
1/11/18
Brent Member
Thank you in advance.
We just purchased a used DMC 3 head sander - Steel Drum, Rubber Drum, and a Platen.
We'll be using 80 grit, 120 grit, 180 grit
My question pertains to the heights of the 'shoes' that are before and after the heads.
For example Head #1 is say .500" above the feedtable frame.
Should the shoe before the 1st head be set to .480? (since I want to remove .020 with the 80 grit on head #1) ...
All the shoes 'float' IE are tensioned by springs.
Below is the order of contacts from the INFEED side. (there are idle rollers but they are on springs and do not have a seperate height adjustment from the shoes)
SHOE
1st Head 80 grit
SHOE
2nd head 120 grit
SHOE
3rd head Platen
SHOE
I presume that there needs to be enough pressure from the shoes to the board so that the board won't slip on the feedbelt (which is my current problem).
BTW we are solely sanding maple rips (not sheeted goods)
1/11/18       #2: Calibrating WIDE BELT sander ...
Hello Brent I don't have an answer for you but I have a question and a suggestion.
When you say shoe do you mean roller or literally a shoe that rubs on the wood?
My suggestion is to call SCM for this information. They made the machine, no? I believe for no cost they will give you technical advise. They likely have someone very well versed on that machine and sanding in general.
Good luck!
1/30/18       #3: Calibrating WIDE BELT sander ...
Adam West  Member
Brent,
The shoe after the first drum should be calibrated to the same height as the first drum in the working position. This means that the drum must be in the down fired position before you start.
The 120 needs to remove exactly .008" of reliably remove the 80 grit scratch so the head and following shoe will be. 008" lower.
The platen with 180 grit will need to remove .003 to .004" to remove the 120. The third head will often have it's own sanding drum, which means it is a combination head with a drum and platen.
If you need more assistance you can contact me at
tech dude @ surfprepsanding. com
I left the spaced to fool the bots that pick up addresses and send spam.
