Subject: Re: Soft close hinges
Soft close hinges
7/3/18
Daniel P
I am starting a set of Cabinets my client wants soft close hinges I normally use salice compact hinges 1/2” overlay not soft close which do you think would be the better soft close either Blum or Salice in the compact 1/2” overlay??
7/4/18       #2: Soft close hinges ...
Joe W Member
I have used both.
Both are good hinges. Only difference is the way they mount to the Face Frame. Thus the manner of up and down adjustment.
Blum has one mounting screw that is also used for up and down adjustment.
Salice has two mounting screws with an dedicated adjustment screw.
I prefer Blum because its easier to remount the hinge if an installer put them on carelessly and I have to fix their mistakes.
If I was doing it myself, I would use the Salice.
7/4/18       #3: Soft close hinges ...
door shop guy
I dont like compact hinges but if i use them i use Salice.
7/4/18       #4: Soft close hinges ...
Daniel P Member
Thanks I am parchel to the Salice also
7/4/18       #5: Soft close hinges ...
Hello Daniel,
I may be a little bias on this topic since I have worked for Salice for 24 years. Here are a few of the important features of our soft close face frame hinge that make a technical innovation and a value product.
I believe you will be very happy with our soft close face frame hinges as well. If you would like a few samples to try, please send me your address.
Thank you for using our other products.
• Available in overlays from ½” to1-3/8” overlays
• Available with 2 or 3 automatic cam adjustments
• Available with 1 screw option (With2 cams).
• Available with 2 screw option (With 3 cams)
• Available in nickel or Titanium plating (Similar to ORB finish)
• Side-to-side adjustment (+3mm, -2mm)
• Variable edge bore distance (TAB) from 3mm to 6mm
• Eliminates butt door gapping issues.
• Height adjustment 2mm
• Depth adjustment
• Easy to operate soft close adjustment switch
• Increase or decrease the speed of closure.
• Soft close always remains even when both hinges are turned “off”
• Silentia mechanism eliminates “door bounce”
• Consistent closing speed from one door to the next
• Cup depth of 11mm (7/16”) allows for use in heavily profiled doors.
• Tight turning radius for ALL overlays permits smaller gaps between doors.
• Suitable for doors up to 7/8” thick.
• Impervious to temperature extremes.
• Zero door protrusion.
• Lifetime warranty
Hope you are having a great 4th.
Dennis Bean
Salice America
View higher quality, full size image (1286 X 1676)
View higher quality, full size image (1284 X 1676)
7/5/18       #6: Soft close hinges ...
Ryan
We use all Blum but also use mostly the arm hinges unless we are doing a cheaper job which almost never happens in the market we work in but we always use soft close. There is a lot more adjustment in an arm hinge than the compact ones. If you are building residential work it is worth the small cost difference to use soft close on everything. People want it and it seems to becoming an industry standard unless the cabinets are very cheap. We like working with Blum but if you are used to compact salice I would use those.
7/23/18       #7: Soft close hinges ...
nathandavidson Member
I would like to know the same thing as I am in the midst of my storage cabinets project as well. Even though it is for my own home, I would like to make sure every single detail falls into place. It would be such a pity if there are changes that need to be done up once the whole setup has been put in place. Hope to get some advice from the seniors here as soft close is really popular nowadays.
7/23/18       #8: Soft close hinges ...
RituGupta Member
Website: http://supercheapselfstorage.com.au/facilities/mel...
I have only heard of the BLUM soft close hinges but I'm sure that there are a number of other options available out there at a cheaper price. Unless of course you customer wants branded hinges on all their storage cupboards. I'm actually pretty sure that you can get some pretty good quality ones if you use the Chinese Aliexpress or Alibaba channels to order them in bulk if you expect more of such orders.
11/20/18       #9: Soft close hinges ...
JeffM
I know it's late in this post, but for what it's worth, I really like the blum soft close arm hinges. They have a small on/off switch so you can have the soft close off, on, very slow closing or not so slow. Very nice.
1/3/24       #10: Soft close hinges ...
CallMeChaz
Numerous soft close manufacturers have switchable soft close options. Anywhere from simple on/off to 3, 4, or even 5 speeds.
1/4/24       #11: Soft close hinges ...
Hi Chaz,
Just an FYI.
Salice soft close hinges have 2 settings. One to increase the tension and the other to decrease the tension. They are never completely "off".
If you have a very small, lightweight door that would require you to turn both hinges, of another brand to the "off" position you would lose all soft close function.
With Salice, you never actually lose the soft close function, you are simply increasing or decreasing the soft close function. Even if you switch both hinges to low resistance, you will still keep the soft close feature
Thank you.
Dennis Bean
Salice America
