Subject: Re: Flip up hinges
Flip up hinges
1/11/19
Daniel P
Need to build in a couple flip up countertops to pass through tops won’t be but about 30” long and about 19” wide what would be the best type of hinge to use on this.
1/11/19       #2: Flip up hinges ...
james e mcgrew Member
Heavy duty Piano hinges, Look to McMaster carr for these,
Flip up pass thru take can see a lot of abuse or stay up 90% of the time
1/11/19       #3: Flip up hinges ...
Paul Miller
I have done a few of these in the past and I have used Soss hinges. But, I try to discourage these flip up bar tops. I try to encourage double action doors. That top will be heavy and when the top is installed, it will protrude into the opening and you will have to have a lip of some kind for the top to rest on, taking more space from the walk way. Also, you will have to be far enough away from the wall if it is next to a wall so that the top can tilt back to the wall.
I have only done two of these applications, both were in commercial bars and when I went back a few years later, both had been removed. Just not practical for a commercial setting where people are coming and going and having to lift up a 20# top everytime they go in and out.
1/11/19       #4: Flip up hinges ...
Alan F.
Flip up is drop hazard when left up.
The Eureka Flip up is very nice hardware
Eureka Flip up
1/11/19       #5: Flip up hinges ...
Matt Krig Member
Check out Counter Balance lift assist
https://www.hghhardware.com/ASSETS/DOCUMENTS/ITEMS/EN/98558_specification%20sheet.
pdf
1/11/19       #6: Flip up hinges ...
Alan F.
Matt,
Those are pretty slick
Thanks!
1/11/19       #7: Flip up hinges ...
Daniel P
Thanks I will check these out I hate using a piano hinge if I can keep from it
