Subject: Re: Inset hinge for half moon blind cabinet
8/30/19
Derek Member
We are having problems finding suitable hinges for our blind corner cabinets with half moons. This is only a problem when building kitchens with inset doors. Overlay doors we will just use a Blum faceframe hinge. However, with inlay the hinge must be behind the faceframe and the half moon support pole is mounted directly behind the faceframe, so a Blum euro hinge does not work, even with a faceframe mounting plate. Have you encountered this?
8/31/19       #2: Inset hinge for half moon blind cab ...
Eddie
I've always use a Blum blind corner hinges with inset application, plate gets mount right behind the FF.
8/31/19       #3: Inset hinge for half moon blind cab ...
Derek,
I would agree with Eddy. The blind corner hinge (Frame-less style) should fit between the face frame and the pull-out pole. There is also a version available with a shorter length of the hinge arm. Here is an example.
Best of Luck,
Dennis
View higher quality, full size image (1019 X 604)
