Subject: Re: True 32
True 32
10/1/19
Kevin Member
I am trying to compare the different 32mm cabinet building systems and I don't see much info on the True 32 system, other than davelers True 32 ten comandments. Can any one point me in the right direction to find info?
10/1/19       #2: True 32 ...
Matt
Bob Buckley's book "True32" is reasonably useful.
Read the reviews on it, the negative ones are priceless but for various reasons. There are some good points made in them but there's also some entertaining bs and posturing.
I read True32 very early in my career (which started in 2004) and it's been foundational to what we do, even though we aren't rigidly on that system today.
True32
10/1/19       #3: True 32 ...
Alan F.
Not sure where the true32 forum went, website is here with some good advice
also here
https://true32customcabinetry.com/need-cabinets-cm/
http://www.true32.com/About-True32com_ep_7.html
10/1/19       #4: True 32 ...
If you post questions Mark Poole, Bob's old (in both definitions) Partner or someone else will answer any questions you post there quite quickly
Tru 32 Community
10/1/19       #5: True 32 ...
Dave L
Linked page currently has 15 (mostly so-called) 32mm systems, including True 32.
32mm Systems
10/2/19       #6: True 32 ...
Kevin Member
Great!
Thanks.
5/8/20       #8: True 32 ...
Al Gerhart Member
True 32 will make you into a businessman so you can survive as a cabinet maker. The system is awesome, find a Grass KISS PDF to get the sizes set up and start at the beginning of the book and start setting up dedicated carts and stations.
Go back to 2002 to 2009 and I was working my rear off with eight employees and struggling. After setting up the True 32 system and door production equipment I can work by myself and crank out nearly as much work as I was doing with all those workers and making four times as much. You set up the machines and system so little can fail or go wrong. You do less finishing, less set up, installs go quicker. Buy the book.
5/9/20       #9: True 32 ...
Dave L
Just a note that KISS boxes are 6mm taller (larger top/bottom reveals, not stackable...) than True 32.
32mm : Styles : Full Overlay
